メインコンテンツにスキップ
LG G5 Camera Sensor Replacement
必要な工具と部品
  1. LG G5 Camera Sensor Replacement, Front Panel Assembly: 手順 1、 2の画像 1 LG G5 Camera Sensor Replacement, Front Panel Assembly: 手順 1、 2の画像 2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Camera Sensor Replacement: 手順 2、 3の画像 1 LG G5 Camera Sensor Replacement: 手順 2、 3の画像 2 LG G5 Camera Sensor Replacement: 手順 2、 3の画像 3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Camera Sensor Replacement: 手順 3、 2の画像 1 LG G5 Camera Sensor Replacement: 手順 3、 2の画像 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Camera Sensor Replacement: 手順 4、 1の画像 1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
  5. LG G5 Camera Sensor Replacement: 手順 5、 2の画像 1 LG G5 Camera Sensor Replacement: 手順 5、 2の画像 2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
  6. LG G5 Camera Sensor Replacement: 手順 6、 2の画像 1 LG G5 Camera Sensor Replacement: 手順 6、 2の画像 2
    • Peel the screen away from the body. The two parts should be completely separated.
  7. LG G5 Camera Sensor Replacement, Screen: 手順 7、 2の画像 1 LG G5 Camera Sensor Replacement, Screen: 手順 7、 2の画像 2
    • Once the screen has been separated from the back of the phone, now you can remove the motherboard.
    • Using the #00 Philips head, remove the six 2.7mm Phillips screws.
  8. LG G5 Camera Sensor Replacement: 手順 8、 2の画像 1 LG G5 Camera Sensor Replacement: 手順 8、 2の画像 2
    • Insert the plastic opening tool between the screen-ribbon-connector and the motherboard, then pull up. It should pop out easily.
  9. LG G5 Camera Sensor Replacement: 手順 9、 1の画像 1
    • Separate the motherboard of the phone from the screen of the phone
  10. LG G5 Camera Sensor Replacement: 手順 10、 2の画像 1 LG G5 Camera Sensor Replacement: 手順 10、 2の画像 2
    この手順で使用する道具:
    • Make sure to transfer the earpiece from the old screen to the new screen or else you wouldn't be able to hear anyone when you make phone calls!
    • The component is fragile so don't try to force it to come out with a pair of tweezers. A pick should be able to wedge it out.
    • Be careful with the adhesive that's connected to it. It's easy to pull out.
  11. LG G5 Camera Sensor Replacement: 手順 11、 1の画像 1
    • Also remove the earpiece casing from the old screen by popping it out with a pair of tweezers.
    • On the new screen, place the casing down first and making sure that it's locked in place. Then place the earpiece on top of it. Gently push it down with your finger until it's secure.
  12. LG G5 Camera Sensor Replacement, Camera Sensor: 手順 12、 3の画像 1 LG G5 Camera Sensor Replacement, Camera Sensor: 手順 12、 3の画像 2 LG G5 Camera Sensor Replacement, Camera Sensor: 手順 12、 3の画像 3
    • Using the plastic opening tool, remove the ribbon attaching the sensor to the motherboard.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Parker Reynolds
メンバー登録日: 10/03/16
936 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016人のメンバー
CPSU-FORTE-F16S18G2
4 メンバー
15のガイドは作成済み
1件のガイドコメント
Is that the camera sensor that has been removed or the wide angle camera?
Thomas Charnley - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 47
今までの合計 4,744
