メインコンテンツにスキップ
LG G4 Screen Assembly Replacement
必要な工具と部品
  1. LG G4 Screen Assembly Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Screen Assembly Replacement: 手順 2、 2の画像 1 LG G4 Screen Assembly Replacement: 手順 2、 2の画像 2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Screen Assembly Replacement: 手順 3、 3の画像 1 LG G4 Screen Assembly Replacement: 手順 3、 3の画像 2 LG G4 Screen Assembly Replacement: 手順 3、 3の画像 3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Screen Assembly Replacement: 手順 4、 3の画像 1 LG G4 Screen Assembly Replacement: 手順 4、 3の画像 2 LG G4 Screen Assembly Replacement: 手順 4、 3の画像 3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Screen Assembly Replacement, Motherboard: 手順 5、 2の画像 1 LG G4 Screen Assembly Replacement, Motherboard: 手順 5、 2の画像 2
    • Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
    • Front-facing camera connector.
    • Rear-facing camera connector.
    • Digitizer connector.
    • The rear-facing camera may be held down to the frame with two sided tape. Try to move the camera with the spudger prior to lifting the motherboard If it does not budge, use the same tool to pry it from the frame to avoid damaging the connector cable in the next step.
  6. LG G4 Screen Assembly Replacement: 手順 6、 2の画像 1 LG G4 Screen Assembly Replacement: 手順 6、 2の画像 2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
  7. LG G4 Screen Assembly Replacement, Screen Assembly: 手順 7、 1の画像 1
    • Use a heat gun or iOpener over the auxiliary port to soften the adhesive that secures it to the plastic housing.
  8. LG G4 Screen Assembly Replacement: 手順 8、 2の画像 1 LG G4 Screen Assembly Replacement: 手順 8、 2の画像 2
    この手順で使用する道具:
    Spudger
    $2.99
    • Insert a nylon spudger into the auxiliary port and gently pry upward to free the port.
  9. LG G4 Screen Assembly Replacement, Other components: 手順 9、 1の画像 1
    • You may also need to remove the vibration motor (the small circular component with two gold contacts), ear-speaker, and two rubber covers on either side of the ear-speaker to transfer these over to the new display assembly.
    • Use a spudger to carefully remove these components and then place them in the new display assembly..
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Sam Goldheart
メンバー登録日: 10/18/12
475,068 ポイント
538のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
123 メンバー
23,765のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 1,741
