メインコンテンツにスキップ
LG G4 Headphone Port Replacement
必要な工具と部品
  1. LG G4 Headphone Port Replacement, Back Cover: 手順 1、 1の画像 1
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Headphone Port Replacement: 手順 2、 2の画像 1 LG G4 Headphone Port Replacement: 手順 2、 2の画像 2
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Headphone Port Replacement: 手順 3、 3の画像 1 LG G4 Headphone Port Replacement: 手順 3、 3の画像 2 LG G4 Headphone Port Replacement: 手順 3、 3の画像 3
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Headphone Port Replacement: 手順 4、 3の画像 1 LG G4 Headphone Port Replacement: 手順 4、 3の画像 2 LG G4 Headphone Port Replacement: 手順 4、 3の画像 3
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Headphone Port Replacement, Headphone Port: 手順 5、 2の画像 1 LG G4 Headphone Port Replacement, Headphone Port: 手順 5、 2の画像 2
    • Gently wedge the plastic opening tool under the ribbons where each of the three cables are connected, and gently lift up to detach the cable.
    • This will allow you to remove the motherboard and give access the headphone port.
  6. LG G4 Headphone Port Replacement: 手順 6、 2の画像 1 LG G4 Headphone Port Replacement: 手順 6、 2の画像 2
    • Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
  7. LG G4 Headphone Port Replacement: 手順 7、 2の画像 1 LG G4 Headphone Port Replacement: 手順 7、 2の画像 2
    • Place the plastic opening tool under the upper left corner of the headphone port, and lift up.
    • The headphone port is held in place with adhesive so it may take some time to pry it loose.
    • Remove the headphone port with your hands.
終わりに
7 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Austin Stratton
メンバー登録日: 08/31/15
1,576 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015人のメンバー
USFT-WOLLERT-F15S16G5
4 メンバー
15のガイドは作成済み
8 件のコメント
In step 5, there are actually three cables, not two.
krdkrdkrd - 返信
My g4's headphone could only produce sound on one side. So i bought a new headphone jack from ebay and replaced it. The problem still persists. Does this mean it could be a motherboard issue?
pholklorr - 返信
Or a headphone issue. You did try a different pair of headphones?
DarkAthena -
i did the same as pholklorr with my g4 but bought oem and still doesn't work you can only hear it from one side
titanzx2500 - 返信
Great! My headphone port couldn't hold my headphones anymore because of wear & tear (they kept falling out) but this guide and a 6 dollar ebay-item fixed it! Thanks a lot.
Moritz Bruder - 返信
I just replace my jack but problem still persist.
Headphones work with app call'soundabout' so problem is not on software. So what cousing this? When i plug headphones nothings happen? Also i dont see any damage on motherboard eveything seems perfectly normal.
Burak Karadenİz - 返信
Help! my headphones would not register on screen, and after replacing the jack, and testing if the jack connection to board was right (I don’t know that is is…) it still won’t show up..
Meow meow - 返信
Mr. Stratton, All the steps are great and, thanks to the pictures are easily followed. However, I have only one remaining question, what do I do next to repair the looseness problem? Can I repair it myself, or do I need to find a new part somewhere and order it?
Ed Hatosy - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 20
今までの合計 8,793
