メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Having technical issues with your LG G3 Vigor that are linked to your devices motherboard? You are in luck, this is the LG G3 Vigor motherboard replacement guide.
パーツ
パーツは指定されていません。
  1. Locate the notch on the bottom right of the phone.
    • Locate the notch on the bottom right of the phone.
  2. Gently pull the cover on the back of the phone off to locate the battery.
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. Remove the battery by lifting from the slot at the bottom of the battery.
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone. Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone. Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. Use the spudger to gently unplug the ribbon cable connected to the motherboard. Remove the front camera.
    • Remove the front camera.
  8. Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. Use the pointed end of a spudger to push back the two motherboard retaining flaps. The motherboard should now be able to be lifted out of the device.
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
終わりに
8 の人々がこのガイドを完成させました。
Jared Stickl
メンバー登録日: 2016年02月08日
407 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 12-5, Eyestone Spring 2016 USF Tampa, Team 12-5, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S12G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,847
