メインコンテンツにスキップ
LG G3 Vigor Headphone Jack Replacement
必要な工具と部品
  1. LG G3 Vigor Headphone Jack Replacement, Rear Case: 手順 1、 1の画像 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Headphone Jack Replacement: 手順 2、 1の画像 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Headphone Jack Replacement, Battery: 手順 3、 1の画像 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Headphone Jack Replacement, Midframe: 手順 4、 1の画像 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Headphone Jack Replacement: 手順 5、 3の画像 1 LG G3 Vigor Headphone Jack Replacement: 手順 5、 3の画像 2 LG G3 Vigor Headphone Jack Replacement: 手順 5、 3の画像 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Headphone Jack Replacement, Rear Facing Camera: 手順 6、 1の画像 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Headphone Jack Replacement, Front Facing Camera: 手順 7、 2の画像 1 LG G3 Vigor Headphone Jack Replacement, Front Facing Camera: 手順 7、 2の画像 2
    • Remove the front camera.
  8. LG G3 Vigor Headphone Jack Replacement, Motherboard: 手順 8、 1の画像 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Headphone Jack Replacement: 手順 9、 2の画像 1 LG G3 Vigor Headphone Jack Replacement: 手順 9、 2の画像 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Headphone Jack Replacement, Headphone Jack: 手順 10、 1の画像 1
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
終わりに
2 の人々がこのガイドを完成させました。
Geoff Wacker
メンバー登録日: 09/30/13
90,313 ポイント
89のガイドは作成済み
コメント 1 件
Works also with D855. There are only a view differences, e.g. screws and a minimal different motherboarddesign.
flux - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 468
