メインコンテンツにスキップ
はじめに
Use this guide to replace the headphone jack in your LG G3 Vigor.
パーツ
パーツは指定されていません。
  1. Locate the notch on the bottom right of the phone.
    • Locate the notch on the bottom right of the phone.
  2. Gently pull the cover on the back of the phone off to locate the battery.
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. Remove the battery by lifting from the slot at the bottom of the battery.
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone. Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone. Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. Use the spudger to gently unplug the ribbon cable connected to the motherboard. Remove the front camera.
    • Remove the front camera.
  8. Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. Use the pointed end of a spudger to push back the two motherboard retaining flaps. The motherboard should now be able to be lifted out of the device.
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
終わりに
2 の人々がこのガイドを完成させました。
Geoff Wacker
メンバー登録日: 2013年09月30日
84,701 ポイント
89のガイドは作成済み
コメント1件
Works also with D855. There are only a view differences, e.g. screws and a minimal different motherboarddesign.
flux - 返信
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 377
