メインコンテンツにスキップ
LG G3 Vigor Display Assembly Replacement
必要な工具と部品
  1. LG G3 Vigor Display Assembly Replacement, Rear Case: 手順 1、 1の画像 1
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Display Assembly Replacement: 手順 2、 1の画像 1
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Display Assembly Replacement, Battery: 手順 3、 1の画像 1
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Display Assembly Replacement, Midframe: 手順 4、 1の画像 1
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Display Assembly Replacement: 手順 5、 3の画像 1 LG G3 Vigor Display Assembly Replacement: 手順 5、 3の画像 2 LG G3 Vigor Display Assembly Replacement: 手順 5、 3の画像 3
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Display Assembly Replacement, Rear Facing Camera: 手順 6、 1の画像 1
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Display Assembly Replacement, Front Facing Camera: 手順 7、 2の画像 1 LG G3 Vigor Display Assembly Replacement, Front Facing Camera: 手順 7、 2の画像 2
    • Remove the front camera.
  8. LG G3 Vigor Display Assembly Replacement, Motherboard: 手順 8、 1の画像 1
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Display Assembly Replacement: 手順 9、 2の画像 1 LG G3 Vigor Display Assembly Replacement: 手順 9、 2の画像 2
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
  10. LG G3 Vigor Display Assembly Replacement, Vibration Motor: 手順 10、 1の画像 1
    • Use a spudger to remove the vibration motor.
    • It may have some slight adhesive, so some force may be necessary.
  11. LG G3 Vigor Display Assembly Replacement, Earpiece Speaker: 手順 11、 1の画像 1
    • Remove the earpiece speaker with the metal spudger by prying it out.
  12. LG G3 Vigor Display Assembly Replacement, Headphone Jack: 手順 12、 1の画像 1
    • Remove the headphone jack by inserting the spudger into the jack and pulling it up and out.
  13. LG G3 Vigor Display Assembly Replacement, Display Assembly: 手順 13、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using tweezers peel back the glued down ribbon cable at the bottom of the phone.
  14. LG G3 Vigor Display Assembly Replacement: 手順 14、 1の画像 1
    • Using a heat gun or the iFixit iOpener tool heat up the edges of the devices screen.
    • After a few minutes heating up the edges of the screen use a metal spudger tool or any other flat tool to dig under the edge of the screen.
    • Once under the edge of the screen work your way around the entire perimeter of the screen and pull the screen off.
  15. LG G3 Vigor Display Assembly Replacement: 手順 15、 1の画像 1
    • Once the screen has come off pull the ribbon cables through the hole and remove the screen completely.
終わりに
6 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Zhong Zhen
メンバー登録日: 02/10/16
675 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 12-5, Eyestone Spring 2016 USF Tampa, Team 12-5, Eyestone Spring 2016人のメンバー
USFT-EYESTONE-S16S12G5
4 メンバー
5のガイドは作成済み
2 件のコメント
i tried to replace the glass, the phone is now stuck at boot screen. the os would load occasionally before. possible battery/water problem. are there any hardware issue that would cause the boot screen (blinking red light)
Ryan Fukushima - 返信
Would anyone know a place to source the glass/lcd assembly. Mucho thanks!
Christopher Obidniak - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 2,204
