はじめに
This guide will show you how to replace a damaged screen on your LG G3.
ビデオの概要
  1. Take your phone and place it screen down.
    • Take your phone and place it screen down.
  2. Start by lifting the back panel using the gap located on the bottom-left side of the phone. Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off. Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off.
    • Start by lifting the back panel using the gap located on the bottom-left side of the phone.
    • Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off.
  3. Remove the battery from the phone. Remove the battery from the phone.
    • Remove the battery from the phone.
  4. Remove the 13 Phillips #00 screws found on the back of the phone. The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
    • Remove the 13 Phillips #00 screws found on the back of the phone.
    • The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
  5. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  6. Locate the same gap used in the earlier step Remove the bottom panel by gently lifting using your fingers
    • Locate the same gap used in the earlier step
    • Remove the bottom panel by gently lifting using your fingers
  7. Remove the top panel by gently lifting with your finger
    • Remove the top panel by gently lifting with your finger
    • Do not pull up too forcefully, as there is a risk of the top panel breaking
  8. Take the plastic opening tool and gently wedge it under where the ribbon cable is connected Gently lift up to disconnect the ribbon cable Repeat until all four ribbon cables are disconnected
    • Take the plastic opening tool and gently wedge it under where the ribbon cable is connected
    • Gently lift up to disconnect the ribbon cable
    • Repeat until all four ribbon cables are disconnected
  9. Remove the motherboard by lifting gently Take care not to damage the ribbon cables if the other components are functional. Damaging them may result in other components not working
    • Remove the motherboard by lifting gently
    • Take care not to damage the ribbon cables if the other components are functional. Damaging them may result in other components not working
  10. Remove the headphone port The headphone port is kept in place with an adhesive, so it may take some time and effort to get it out
    • Remove the headphone port
    • The headphone port is kept in place with an adhesive, so it may take some time and effort to get it out
  11. If you are going to be using a screen assembly with a pre-installed frame, you may stop here and follow the previous steps in reverse with your new screen assembly. Otherwise, you will now transfer the LCD bezel as well as the speaker grille. Remove the metal tape to reveal the ribbon cables connected to the screen The metal tape is stuck on there pretty well. Get the plastic opening tool under the right-hand side and corners and slowly work your way to getting it off
    • If you are going to be using a screen assembly with a pre-installed frame, you may stop here and follow the previous steps in reverse with your new screen assembly. Otherwise, you will now transfer the LCD bezel as well as the speaker grille.
    • Remove the metal tape to reveal the ribbon cables connected to the screen
    • The metal tape is stuck on there pretty well. Get the plastic opening tool under the right-hand side and corners and slowly work your way to getting it off
    • Be careful when removing the metal tape. We can reuse it after we replace the screen
  12. If you wish to preserve the LCD screen for whatever reason, it is recommended you use a heat gun around the sides in order to weaken the adhesive that keeps the screen in place Take something thin, such as a knife, and wedge it between the screen and the body of the phone
    • If you wish to preserve the LCD screen for whatever reason, it is recommended you use a heat gun around the sides in order to weaken the adhesive that keeps the screen in place
    • Take something thin, such as a knife, and wedge it between the screen and the body of the phone
    • One you have created some space, wedge your plastic opening tool into the space and remove the knife
    • Move your plastic opening tool up and down the side of the phone while lightly pulling up. Repeat this for all sides until the screen comes out
    • If you wish to preserve the LCD screen, be careful how deep you wedge the plastic opening tool in and how hard you pull up to get the screen out. Depending on the depth of the plastic opening tool and strength used, there is a high risk of damaging the LCD screen
    • Remove the old adhesive from the body and replace with new adhesive so the new screen will stay in place
  13. Before reassembly, be sure to transfer the front speaker grille if it is not included with the new screen. If not, carefully push the grille out from the old screen, then reinsert it on the new LCD.
    • Before reassembly, be sure to transfer the front speaker grille if it is not included with the new screen. If not, carefully push the grille out from the old screen, then reinsert it on the new LCD.
まとめ
118 の人々がこのガイドを完成させました。
Naoto
メンバー登録日: 2014年10月16日
4,487 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 1-3, Duarte Fall 2014 UMass Dartmouth, Team 1-3, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G3
4 メンバー
14のガイドは作成済み
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
cabinlife27030 - 返信
Has it sustained any water damage?
Josiah Leas -
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt -
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
tufekcisencer -
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
fsnaderfb -
統計データを表示:
過去 24時間: 8
過去 7 日: 116
過去 30 日: 474
今までの合計 239,868
