メインコンテンツにスキップ
LG G3 Power & Volume Button Cable Replacement
必要な工具と部品
  1. LG G3 Power & Volume Button Cable Replacement, Back Cover: 手順 1、 2の画像 1 LG G3 Power & Volume Button Cable Replacement, Back Cover: 手順 1、 2の画像 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Power & Volume Button Cable Replacement: 手順 2、 2の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 2、 2の画像 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Power & Volume Button Cable Replacement, Battery: 手順 3、 2の画像 1 LG G3 Power & Volume Button Cable Replacement, Battery: 手順 3、 2の画像 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Power & Volume Button Cable Replacement: 手順 4、 2の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 4、 2の画像 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Power & Volume Button Cable Replacement, Loudspeaker: 手順 5、 1の画像 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Power & Volume Button Cable Replacement: 手順 6、 2の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 6、 2の画像 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Power & Volume Button Cable Replacement: 手順 7、 3の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 7、 3の画像 2 LG G3 Power & Volume Button Cable Replacement: 手順 7、 3の画像 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Power & Volume Button Cable Replacement, Motherboard Cover Assembly: 手順 8、 1の画像 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Power & Volume Button Cable Replacement: 手順 9、 3の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 9、 3の画像 2 LG G3 Power & Volume Button Cable Replacement: 手順 9、 3の画像 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Power & Volume Button Cable Replacement: 手順 10、 3の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 10、 3の画像 2 LG G3 Power & Volume Button Cable Replacement: 手順 10、 3の画像 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: 手順 11、 2の画像 1 LG G3 Power & Volume Button Cable Replacement, Power & Volume Button Flex Cable: 手順 11、 2の画像 2
    • Remove the last screw attaching the rear camera lens to the frame.
    • Now use a plastic spudger to carefully remove the camera lens.
  12. LG G3 Power & Volume Button Cable Replacement: 手順 12、 3の画像 1 LG G3 Power & Volume Button Cable Replacement: 手順 12、 3の画像 2 LG G3 Power & Volume Button Cable Replacement: 手順 12、 3の画像 3
    • Using the spudger, release power & volume button flex from adhesive carefully.
  13. LG G3 Power & Volume Button Cable Replacement: 手順 13、 1の画像 1
    • Finally, remove the flex.
終わりに
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Sophia
メンバー登録日: 03/25/14
43,810 ポイント
62のガイドは作成済み
コメント 1 件
I bought a more powerful battery. 6800 mah .instead of the 3000mah OEM . Ia there any problem using it?
mitoll - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 12
今までの合計 21,999
