メインコンテンツにスキップ
LG G3 Earpiece Replacement
必要な工具と部品
  1. LG G3 Earpiece Replacement, Back Cover: 手順 1、 2の画像 1 LG G3 Earpiece Replacement, Back Cover: 手順 1、 2の画像 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Earpiece Replacement: 手順 2、 2の画像 1 LG G3 Earpiece Replacement: 手順 2、 2の画像 2
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Earpiece Replacement, Battery: 手順 3、 2の画像 1 LG G3 Earpiece Replacement, Battery: 手順 3、 2の画像 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Earpiece Replacement: 手順 4、 2の画像 1 LG G3 Earpiece Replacement: 手順 4、 2の画像 2
    • Lift the battery out of its recess and remove it.
  5. LG G3 Earpiece Replacement, Loudspeaker: 手順 5、 1の画像 1
    • Remove the four Phillips #00 screws (4 mm length).
  6. LG G3 Earpiece Replacement: 手順 6、 2の画像 1 LG G3 Earpiece Replacement: 手順 6、 2の画像 2
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
  7. LG G3 Earpiece Replacement: 手順 7、 3の画像 1 LG G3 Earpiece Replacement: 手順 7、 3の画像 2 LG G3 Earpiece Replacement: 手順 7、 3の画像 3
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
  8. LG G3 Earpiece Replacement, Motherboard Cover Assembly: 手順 8、 1の画像 1
    • Remove the eight Phillips #00 screws (4 mm length).
  9. LG G3 Earpiece Replacement: 手順 9、 3の画像 1 LG G3 Earpiece Replacement: 手順 9、 3の画像 2 LG G3 Earpiece Replacement: 手順 9、 3の画像 3
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
  10. LG G3 Earpiece Replacement: 手順 10、 3の画像 1 LG G3 Earpiece Replacement: 手順 10、 3の画像 2 LG G3 Earpiece Replacement: 手順 10、 3の画像 3
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
  11. LG G3 Earpiece Replacement, Motherboard: 手順 11、 2の画像 1 LG G3 Earpiece Replacement, Motherboard: 手順 11、 2の画像 2
    • Use a spudger to pry up and disconnect the display flex cable.
  12. LG G3 Earpiece Replacement: 手順 12、 2の画像 1 LG G3 Earpiece Replacement: 手順 12、 2の画像 2
    • Use a spudger to pry up and disconnect the digitizer flex cable.
  13. LG G3 Earpiece Replacement: 手順 13、 2の画像 1 LG G3 Earpiece Replacement: 手順 13、 2の画像 2
    • Use a spudger to pry up and disconnect the rear camera flex cable.
  14. LG G3 Earpiece Replacement: 手順 14、 2の画像 1 LG G3 Earpiece Replacement: 手順 14、 2の画像 2
    • Use a spudger to pry up and disconnect the front camera flex cable.
  15. LG G3 Earpiece Replacement: 手順 15、 2の画像 1 LG G3 Earpiece Replacement: 手順 15、 2の画像 2
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
  16. LG G3 Earpiece Replacement: 手順 16、 2の画像 1 LG G3 Earpiece Replacement: 手順 16、 2の画像 2
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
  17. LG G3 Earpiece Replacement: 手順 17、 2の画像 1 LG G3 Earpiece Replacement: 手順 17、 2の画像 2
    • Grab the top section of the motherboard and carefully lift it out of the phone.
  18. LG G3 Earpiece Replacement, Earpiece speaker: 手順 18、 2の画像 1 LG G3 Earpiece Replacement, Earpiece speaker: 手順 18、 2の画像 2
    • During removal of the earpiece speaker, remove it together with the foam gasket underneath.
    • Use a pair of tweezers to remove the earpiece speaker.
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
8 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Dominik Schnabelrauch
メンバー登録日: 11/23/16
203,299 ポイント
682のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
3 件のコメント
Can't just remove the earpiece without removing the motherboard?
bassamxp - 返信
unless you broke the phone, NO
Tarik Kaya -
To reassemble the earpiece what kind of adhesive do I need?
DukeCrom - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 10
今までの合計 8,689
