はじめに
The battery can be used to hold a charge that powers the watch for a period of time.
必要な工具と部品
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Add colored markup to indicate location of the 3 screws.
Use a plastic opening tool to pry the battery out of the device.
Thanks this was very helpful.
Thanks for your instructions
Thank you for this guide!
70 の人々がこのガイドを完成させました。
13 件のコメント
The question is where i can find such battery ?
It did help, small correction - Use a T4 instead of T5 screw driver
On my G Watch R the T5 screw driver perfektly fits.
Perfekt Instruktion only the estimated time of 5 minutes ist very ambigous lol. Thanks a lot
Did you guys retain water resistance after the battery swap?
There is an o-ring type seal connected to the backplate. As long as you are careful when taking the backplate off and also make sure that the channel this fits into when you re-assemble is clean, you should be OK. It’s only about 1mm from the edge of the backplate, so don’t dig too deep with your loosening tool when taking the plate off.
The above instructions worked fine for me as someone who has never done anything like this before … watch is now back to being fully-operational with the latest version of android wear and great battery life. I too used fonejoy .. delivery within 24 hours :) I’d never tried re-connecting this type of PCB connector before and fiddled around for some time before realising that they click into place quite easily. This is probably a 30 minutes job for most of us rather than 5 minutes.
Where can I get the battery.. Cos am in Benin
Works perfectly, with one remark. The original spare LG battery I ordered had a slightly different shape. in order to make it fit I had to push the new battery upwards, not center it (intuitively done)
great guide!
I am very happy with this instruction. LG watch R is one of the best supported devices for AsteroidOS.
https://petergamma.org/page-2/
herefore it is very important that the battery can be replaced. Many thanks for the instruction.
Great instructions, thank you so much !
So i bought a torx t5…but it is tooo big. It must br torx t4
Jetze Kooistra - 返信
I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
What should I do? (Can anything be done?)
John Maher - 返信
Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
Andrew L rambeaut -
Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
Ernst Kranke - 返信
