はじめに
From taking off the back cover to placing in your new camera, this guide will lay out each step. You are experiencing issues with your back camera, this guide has everything you will need to know.
必要な工具と部品
Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
I need help urgently please
Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
Fully remove the motherboard by prying upward with the plastic opening tool.
These pictures sb. numbered
The pictures shown need to be#”d and also what part # do we order???
Gently wedge the plastic opening tool under the ribbon where the rear camera cable is connected. Slowly lift up to detach the cable from the mother board and replace the rear camera accordingly.
