メインコンテンツにスキップ
LG G Stylo Motherboard Replacement
必要な工具と部品
  1. LG G Stylo Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG G Stylo Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Make sure that you power off the phone before beginning.
    • Remove the back cover by placing the plastic opening tool on the bottom left side of the device and gently prying up.
    • There is a small slit that fits the plastic opening tool perfectly on the left side.
  2. LG G Stylo Motherboard Replacement: 手順 2、 2の画像 1 LG G Stylo Motherboard Replacement: 手順 2、 2の画像 2
    • Insert the plastic opening tool into the indent at the bottom of the battery and lift up. Fully remove the battery with your fingers.
    My phone is showing USB when charging instead of AC and when removing the charger it's show discharging instead of Not charging.... Don't know why it is not working properly....
    George japhet - 返信
    I need help urgently please
    George japhet - 返信
  3. LG G Stylo Motherboard Replacement, Motherboard: 手順 3、 2の画像 1 LG G Stylo Motherboard Replacement, Motherboard: 手順 3、 2の画像 2
    • Carefully use the Phillips #00 screwdriver to remove the eleven 3.9mm visible screws found on the back. The screws to be removed are marked with the given indicators.
  4. LG G Stylo Motherboard Replacement: 手順 4、 3の画像 1 LG G Stylo Motherboard Replacement: 手順 4、 3の画像 2 LG G Stylo Motherboard Replacement: 手順 4、 3の画像 3
    • When you have finished removing all of the screws, place the plastic opening tool in the groove at the bottom left corner of the motherboard cover and lift up.
    • Make sure to remove the SIM card before you remove the motherboard cover. You can get the cover off without doing this, but the SIM card will be stuck underneath the cover once you put it back together.
    • This part could be more difficult if you have never removed the motherboard cover. If difficulty arises, pry the plastic opening tool into each groove along the edge of the motherboard cover until it releases.
    • Once a clip is released, you can detach the motherboard cover with your fingers and set aside.
  5. LG G Stylo Motherboard Replacement: 手順 5、 3の画像 1 LG G Stylo Motherboard Replacement: 手順 5、 3の画像 2 LG G Stylo Motherboard Replacement: 手順 5、 3の画像 3
    • Carefully place the plastic opening tool under the ribbons where the cables are connecting and lift up to detach the cables.
    • Keep in mind to be careful with the ribbons, because they are small components and important for the device's functionality.
    • The third photo attached depicts what the ribbons look like when they are successfully detached.
  6. LG G Stylo Motherboard Replacement: 手順 6、 2の画像 1 LG G Stylo Motherboard Replacement: 手順 6、 2の画像 2
    • Fully remove the motherboard by prying upward with the plastic opening tool.
    • This step will be quite simple if all the ribbons have been detached correctly.
    These pictures sb. numbered
    superbike-shaun - 返信
    The pictures shown need to be#”d and also what part # do we order???
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alessandro Di Bella
メンバー登録日: 02/09/16
253 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 11-7, Cheng Spring 2016 USF Tampa, Team 11-7, Cheng Spring 2016人のメンバー
USFT-CHENG-S16S11G7
4 メンバー
14のガイドは作成済み
6 件のコメント
Do you know where the wifi chip is?
Jeremy Vega - 返信
Do you guys know where i can get a new motherboard for an lg stylo?
Alessandro Enceladus - 返信
A family member of mine snapped my phone in half with my baby's pictures on it.
I asked my boyfriend to back up the pictures… well, he figured after thanksgiving when I will have more happy photos…
So, any hope of getting them?
The motherboard is partly missing.
The SD card was full so most were on the phone.
Lost Cause - 返信
My LG stylus 2 power ic is damaged can you repair it please
Tusha - 返信
I would like to know if I can change the micro USB charging port to the'C’ type on a k20
Ron Hardy - 返信
Achte carte mere LG stylus2 vs 2016
Bahaa Eddinne - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 7,086
