メインコンテンツにスキップ
LG G Pad X 8.3 Speaker Replacement
必要な工具と部品
  1. LG G Pad X 8.3 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Speaker Replacement: 手順 2、 1の画像 1
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Speaker Replacement: 手順 3、 1の画像 1
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Speaker Replacement: 手順 4、 3の画像 1 LG G Pad X 8.3 Speaker Replacement: 手順 4、 3の画像 2 LG G Pad X 8.3 Speaker Replacement: 手順 4、 3の画像 3
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Speaker Replacement: 手順 5、 1の画像 1
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Speaker Replacement: 手順 6、 1の画像 1
    • Lift the battery with your fingers and remove it from the device.
  7. LG G Pad X 8.3 Speaker Replacement, Speaker: 手順 7、 1の画像 1
    • With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
    • Use the magnetic mat to keep track of the tiny screw(s).
  8. LG G Pad X 8.3 Speaker Replacement: 手順 8、 1の画像 1
    • Lift and remove the speaker with your finger.
終わりに
作成者
2人の作成者と共同で作成されました。
Michael H
メンバー登録日: 04/09/18
531 ポイント
4のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 146
