このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Start at a corner and pry the screen up with a plastic opening tool.
Slide the tool in the seam at the edge of the screen.
Wedge additional plastic opening tools in the seam to help lift the screen.
Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
この手順は未翻訳です。 翻訳を手伝う。
With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
Use a magnetic mat to keep track of these tiny screws for later reassembly.
ある他の人がこのガイドを完成しました。
2 件のコメント
This looks to be a helpful Guide, but there is no help in WHERE to purchase a battery and if there could be a different battery with higher capacity and a longer life as a choice. As a Consumer, this type of information would be helpful.
I cannot get a wedge tool in to remove the screen on my LG G Pad X 10.1. Any suggestions?
