メインコンテンツにスキップ
LG G Pad X 8.3 Battery Replacement
必要な工具と部品
  1. LG G Pad X 8.3 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Battery Replacement: 手順 2、 1の画像 1
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Battery Replacement: 手順 3、 1の画像 1
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Battery Replacement: 手順 4、 3の画像 1 LG G Pad X 8.3 Battery Replacement: 手順 4、 3の画像 2 LG G Pad X 8.3 Battery Replacement: 手順 4、 3の画像 3
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Battery Replacement: 手順 5、 1の画像 1
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Battery Replacement: 手順 6、 1の画像 1
    • Lift the battery with your fingers and remove it from the device.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Roxanne McPeck
メンバー登録日: 04/09/18
345 ポイント
1ガイドが承認済み
チーム
2 件のコメント
This looks to be a helpful Guide, but there is no help in WHERE to purchase a battery and if there could be a different battery with higher capacity and a longer life as a choice. As a Consumer, this type of information would be helpful.
Harvey Rothenberg - 返信
I cannot get a wedge tool in to remove the screen on my LG G Pad X 10.1. Any suggestions?
Hillary Brandeberry - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 5,296
