はじめに
This guide will take you through the very easy process of replacing the downward facing speaker that has either died or blown out.
必要な工具と部品
Power off the device before starting speaker replacement.
Remove SD card and SIM Card.
With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
