メインコンテンツにスキップ
LG G Pad X 8.0 Battery Replacement
必要な工具と部品
  1. LG G Pad X 8.0 Battery Replacement, Removing Backplate: 手順 1、 1の画像 1
    • Power off the device before starting battery replacement.
    • Remove SD card and SIM Card.
    • With the opening tool, gently pry the back plate away from the main board. The corners are the easiest spots to start at.
  2. LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: 手順 2、 2の画像 1 LG G Pad X 8.0 Battery Replacement, Peeling Back Cover Off: 手順 2、 2の画像 2
    • Gently pull the back cover away from the adhesive on the battery.
    • It may be possible to use a blow dryer on low heat but I'd advise against it unless absolutely necessary.
  3. LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: 手順 3、 3の画像 1 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: 手順 3、 3の画像 2 LG G Pad X 8.0 Battery Replacement, Detaching Old Battery: 手順 3、 3の画像 3
    • Slowly and gently lift the power cable upwards.
    • Unscrew the 4 screws keeping the battery in place, set aside.
  4. LG G Pad X 8.0 Battery Replacement, Removing the Battery: 手順 4、 1の画像 1
    • Remove the battery by pulling up gently.
終わりに
17 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
[deleted]
メンバー登録日: 05/18/17
1,146 ポイント
3のガイドは作成済み
10 件のコメント
I was going to do this to fix my son's tablet and then I looked up the cost of a replacement battery on eBay. Almost $100! Do you have a good source for a new battery?
poeticpyr07 - 返信
Unfortunately, no, there does not seem to be a good part supplier for the G Pad X 8.0. As you mention, the best I see is eBay at $82.
[deleted] -
2 years on they're $14
Carlos Mendonca -
I have researched this battery, the LG BL T-20. I found one that is 4800 MaH. The LG Gpad X8.0 has the same battery that is 4650 MaH. If I order the 4800 MaH, will it work?
luvgod10 - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 17
過去 30 日: 41
今までの合計 14,956
