メインコンテンツにスキップ
LG G Pad F 7.0 Motherboard Replacement
必要な工具と部品
  1. LG G Pad F 7.0 Motherboard Replacement, Rear Camera: 手順 1、 2の画像 1 LG G Pad F 7.0 Motherboard Replacement, Rear Camera: 手順 1、 2の画像 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out
    • Remove SIM card and set aside
  2. LG G Pad F 7.0 Motherboard Replacement: 手順 2、 1の画像 1
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Motherboard Replacement: 手順 3、 2の画像 1 LG G Pad F 7.0 Motherboard Replacement: 手順 3、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use the plastic opening tool to pry up the ribbon cable connecting to the camera unit.
    • One the ribbon cable has been detached, use the tweezers to pull up the camera. It is attached with adhesive so pull up gently to remove it.
    • Once the old camera unit is removed, replace with new unit and reassemble in reverse order of guide.
  4. LG G Pad F 7.0 Motherboard Replacement, Motherboard: 手順 4、 1の画像 1
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  5. LG G Pad F 7.0 Motherboard Replacement: 手順 5、 2の画像 1 LG G Pad F 7.0 Motherboard Replacement: 手順 5、 2の画像 2
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
  6. LG G Pad F 7.0 Motherboard Replacement: 手順 6、 2の画像 1 LG G Pad F 7.0 Motherboard Replacement: 手順 6、 2の画像 2
    • Locate the front facing camera ribbon cable attachment on the motherboard
    • Leave the ribbon cable disconnected.
  7. LG G Pad F 7.0 Motherboard Replacement: 手順 7、 2の画像 1 LG G Pad F 7.0 Motherboard Replacement: 手順 7、 2の画像 2
    • Locate the six Phillips head screws on the LG G Pad F 7.0 Motherboard
    • Use Phillips #0 Screwdriver to unscrew the six screws.
  8. LG G Pad F 7.0 Motherboard Replacement: 手順 8、 2の画像 1 LG G Pad F 7.0 Motherboard Replacement: 手順 8、 2の画像 2
    • Remove the motherboard by prying it out with the plastic opening tool (as shown in image).
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jose Hurtado
メンバー登録日: 01/25/17
329 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G5
3 メンバー
10のガイドは作成済み
コメント 1 件
Some spelling errors but overall simple to follow
Jonah Basl - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 534
