メインコンテンツにスキップ
LG G Pad F 7.0 Charging Port Replacement
必要な工具と部品
  1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: 手順 1、 2の画像 1 LG G Pad F 7.0 Charging Port  Replacement, Charging Port: 手順 1、 2の画像 2
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Charging Port  Replacement: 手順 2、 2の画像 1 LG G Pad F 7.0 Charging Port  Replacement: 手順 2、 2の画像 2
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Charging Port  Replacement: 手順 3、 1の画像 1
    • Locate the top of the large orange ribbon cable.
    • Pry it off with the plastic opening tool as shown in the image.
  4. LG G Pad F 7.0 Charging Port  Replacement: 手順 4、 2の画像 1 LG G Pad F 7.0 Charging Port  Replacement: 手順 4、 2の画像 2
    • Remove the gyroscope (the blue rectangular cube) located near the bottom of the device with the plastic opening tool as shown in the image.
    • Remove the speaker located in the bottom right corner of the device with the plastic opening tool as shown in the image.
  5. LG G Pad F 7.0 Charging Port  Replacement: 手順 5、 2の画像 1 LG G Pad F 7.0 Charging Port  Replacement: 手順 5、 2の画像 2
    この手順で使用する道具:
    購入する
    • Remove the two screws located on the charging port as seen in the image using the Phillips screwdriver.
    • Using the tweezers, remove the orange ribbon cable along with the charging port.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Erik
メンバー登録日: 01/25/17
293 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017人のメンバー
CPSU-BANGHART-W17S8G5
3 メンバー
10のガイドは作成済み
4 件のコメント
Good work, Pictures are clear and easy to follow
Jonah Basl - 返信
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Alan Siebens - 返信
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Stands For Jesus - 返信
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 16
今までの合計 4,076
