With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
The cable is attached with an adhesive.
These images use a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
Remove the ribbon cable from the device.
Use a plastic opening tool to lift the motherboard out of the device.
Use a plastic opening tool to lift the front facing camera out of the device.
このガイドを埋め込む
ご自身のサイト/フォーラムに小さなウィジェットとしてこのガイドを埋め込むには、サイズを選択し下のコードをコピーしてください。
プレビュー
