はじめに
If you need to replace a component inside the LG G Pad 8.3, you will need to remove the back panel. This guide will teach you how to remove the back panel.
パーツ
パーツは指定されていません。
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
もう少しです!
終わりに
