メインコンテンツにスキップ
LG G Pad 7.0 Motherboard Replacement
必要な工具と部品
  1. LG G Pad 7.0 Motherboard Replacement, Front Panel: 手順 1、 2の画像 1 LG G Pad 7.0 Motherboard Replacement, Front Panel: 手順 1、 2の画像 2
    • The screen assembly is secured to the plastic backing with clips.Insert the plastic opening tool between the screen and plastic.
    • Carefully work your way around the device making sure not to go too deep damaging any eternal components, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Motherboard Replacement, Connectors: 手順 2、 3の画像 1 LG G Pad 7.0 Motherboard Replacement, Connectors: 手順 2、 3の画像 2 LG G Pad 7.0 Motherboard Replacement, Connectors: 手順 2、 3の画像 3
    • Remove the red marked connectors by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
    • You will have to remove the metallic tape near the bottom of the tablet to disconnect the display cable.
    • Remove the three connectors marked in orange by gently prying them upwards. The cables are very fragile so be careful not to rip them.
  3. LG G Pad 7.0 Motherboard Replacement, Logic Board: 手順 3、 2の画像 1 LG G Pad 7.0 Motherboard Replacement, Logic Board: 手順 3、 2の画像 2
    • Remove the 7 screws marked in red that are securing the logic board to the case.
    • Be sure that all the connectors marked in orange are removed before pulling out the mother board.
    • Very carefully remove the logic board after the screws have been removed
  4. LG G Pad 7.0 Motherboard Replacement: 手順 4、 3の画像 1 LG G Pad 7.0 Motherboard Replacement: 手順 4、 3の画像 2 LG G Pad 7.0 Motherboard Replacement: 手順 4、 3の画像 3
    • Remove the two screw marked in red.
    • Using the tweezers , gently pull out the metal bracket that holds the charging port in place.
    • Carefully pull out the ribbon connector in orange.
    • Remove the one screw that holds the speaker in place.
    • Slowly pull out the speaker.
  5. LG G Pad 7.0 Motherboard Replacement: 手順 5、 2の画像 1 LG G Pad 7.0 Motherboard Replacement: 手順 5、 2の画像 2
    • Insert your new mother board with the 7 screws
    • Reconnect all the connectors marked in red back to the mother board.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
echow2001
メンバー登録日: 09/05/15
2,117 ポイント
4のガイドは作成済み
チーム
LGBTQ Technicians LGBTQ Technicians人のメンバー
Community
14 メンバー
23のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 8
今までの合計 2,050
