メインコンテンツにスキップ
LG G Pad 7.0 LTE Front Screen Replacement
必要な工具と部品
  1. LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: 手順 1、 3の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: 手順 1、 3の画像 2 LG G Pad 7.0 LTE Front Screen Replacement, Open up the tablet: 手順 1、 3の画像 3
    • Remove the MicroSD Memory card, Sim Card, and the metal Sim Card Holder.
    • Put them off to the side for reassembly.
    • Now you can slowly use a plastic opening tool to go around the edge of the tablet to slowly pry upward.
  2. LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: 手順 2、 3の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: 手順 2、 3の画像 2 LG G Pad 7.0 LTE Front Screen Replacement, Remove the orange port strip: 手順 2、 3の画像 3
    • Now that we have the back cover and can remove the orange port strip.
    • Use the spudger to gently remove the strip by pushing upward slowly.
  3. LG G Pad 7.0 LTE Front Screen Replacement, Disconnect the battery: 手順 3、 2の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Disconnect the battery: 手順 3、 2の画像 2
    • To disconnect the battery you are going to unplug the cables.
    • Use the tweezers to gently hold the cables and slowly push upward to detach it.
    • Don't be too rough and pinch the cables with the tweezers. Take your time and slowly detach.
  4. LG G Pad 7.0 LTE Front Screen Replacement, Unscrew the motherboard: 手順 4、 1の画像 1
    • Remove the 7 black screws on the motherboard.
    • Put them to the side for reassembly.
  5. LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: 手順 5、 3の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: 手順 5、 3の画像 2 LG G Pad 7.0 LTE Front Screen Replacement, Detach camera connections from motherboard.: 手順 5、 3の画像 3
    • Detach the black tag in the middle of the motherboard. This is the main camera connection.
    • Locate the next camera connection at the top of the motherboard. Disconnect this black tag for your front camera.
    • Now you are able to remove the motherboard from the tablet.
  6. LG G Pad 7.0 LTE Front Screen Replacement, Detach main camera: 手順 6、 2の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Detach main camera: 手順 6、 2の画像 2
    • Now that the motherboard is removed, you can now access the main camera for removal. Gently use the tweezers to do this.
    • Put to the side for reassembly.
  7. LG G Pad 7.0 LTE Front Screen Replacement, Remove front speaker: 手順 7、 2の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Remove front speaker: 手順 7、 2の画像 2
    • Using the Phillips screwdriver, remove the screw and put aside for reassembly.
  8. LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: 手順 8、 3の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: 手順 8、 3の画像 2 LG G Pad 7.0 LTE Front Screen Replacement, Remove orange port strip entirely.: 手順 8、 3の画像 3
    • Two screws are holding the metal plate down. Remove the screws and put aside.
    • Use the tweezers to remove the tape to show the connection.
    • Use the spudger to push up and remove the connection.
    • Use the tweezers to completely remove charging port from tablet. Put aside for reassembly.
    Be careful when pulling off the right edge of charger port cable, its tiny and can be easily broken, take your time with the adhesive
    Tina Ramirez - 返信
    Use flat edge of spudger to get underneath before prying upward, then it detaches easily
    Tina Ramirez - 返信
  9. LG G Pad 7.0 LTE Front Screen Replacement, Remove battery: 手順 9、 2の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Remove battery: 手順 9、 2の画像 2
    • To remove the battery, use the spudger or the Jimmy tool to slowly work your way around the battery.
    • It is being held on by strips of tape so be patient with it. Work it a little bit at a time to remove the battery from the tablet.
    • Put it aside for reassembly.
  10. LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: 手順 10、 3の画像 1 LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: 手順 10、 3の画像 2 LG G Pad 7.0 LTE Front Screen Replacement, Remove front screen: 手順 10、 3の画像 3
    • Apply a heat gun or iOpener to front of screen to allow it to warm up the glue.
    • Use opening tool and work your way around the front of the screen. You may have to alternate applying the heat and prying to get it loose enough to separate.
    • Be careful not overdo the heat. Use a low temperature and take your time to separate the screen.
    • Clean the black backing off of any glass still sticking to it. Mine had a lot so I had to scrape for awhile to get all the little pieces off to have a clean surface to apply the new replacement screen.
    • Apply new screen to black backing.
終わりに
To reassemble your device, follow these instructions in reverse order. You will need new adhesive to apply upon reassembly.
**The time estimate is put at an hour but depending on how much broken glass you are dealing with and having to scrap off old adhesive glue - it could take longer so please have patience when dealing with glass to not injury yourself.
38 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
MissHeather
メンバー登録日: 07/03/15
1,674 ポイント
2のガイドは作成済み
チーム
Android Alliance Android Alliance人のメンバー
Community
86 メンバー
699のガイドは作成済み
18 件のコメント
Great help..........thanks
James Smith - 返信
Good job but I have just 1 speaker out.
James Smith - 返信
Do you mean you took one speaker out or the speaker is no longer functioning properly?
MissHeather -
Hello Ms. Heather I cannot access the motherboard, I am unable to remove the back cover. Pls help
kmonicaholloway - 返信
Are you using a prying tool and going around the edges of the tablet to open it? What exactly is happening?
MissHeather -
The backlight stopped working after trying to test the screen before install. Any ideas as to why this would stop?
The iPhone Guy - 返信
If you can, I would retrace your steps to make sure everything is hooked up accordingly and test the parts for anything that might be damaged. Check the cables and see if the connectors are dirty or anything is obstructing a secure connection.
MissHeather -
is there a way to get my lg pad repaired professionally and cheap?
Jasper the crystal gem - 返信
There's actually an easier way: order the replacement part from Ebay; follow the instructions above until step 9 and you can't go wrong. A seller in Ebay have the complete screen assembly for $34.76. A real bargain. This is the Ebay item number: 172233283111.
macrossps -
Macrossps answered it pretty nicely. If you don't have the time and tools, I understand wanting to get it repaired professionally but understand that on old devices it can be cheaper to do it yourself. You can find people who will do it for you but it depends on your location and what services are available there. I like macrossps idea on the full screen assembly as an option too.
MissHeather -
Where can I buy proper adhesive?
Chris Gordon - 返信
I use amazon to get my tape. Make sure it is 3m or you will be disappointed. They have a variety of thicknesses to suit your needs.
Jeremy Dack -
I used Amazon as well for adhesive tape and got a good deal. Definitely check there if you want a good deal or have a Prime Account.
MissHeather -
I am looking to do a digitizer only repair. Is the glass LOCA glued to the display?
Jeremy Dack - 返信
What caused the screen to have fine lines all over so you cannot see what's on
Mondelle Amsterdam - 返信
I have the screen assembly out of my tablet but do not understand how to remove it from the plastic housing or when my new screen arrives will it have the plastic frame. I wish I could take a pic and send to you so you could see what I am talking about. Why do you techies make one guide that is supposed to cover several different procedures. The way they are written people following step by step to replace their screen will also be unhooking their motherboard and disconnecting their speaker and removing their battery plus disconnecting several items unnecessarily that could potentially damage the device.
Forrest Faulkner - 返信
Do you all carry the screen for the lg gpad 7.0
djohnson601 - 返信
I just need to rplace the screen which is black. Do I relly have to remove all the other parts inside?
louandtom13 - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 30
今までの合計 39,850
