メインコンテンツにスキップ
LG G Pad 7.0 LTE Front Facing Camera Replacement
必要な工具と部品
  1. LG G Pad 7.0 LTE Front Facing Camera Replacement, Removing the Back Cover: 手順 1、 1の画像 1
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Front Facing Camera Replacement: 手順 2、 1の画像 1
    この手順で使用する道具:
    Anti-Static Wrist Strap
    $7.95
    購入する
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Front Facing Camera Replacement, Motherboard: 手順 3、 1の画像 1
    • Disconnect the battery connector by prying it upwards (red marker).
    • Be careful not to damage it while doing so.
    • Remove the ribbon cables by prying them upwards with a plastic pry tool ).
    • Do not bend the cable or connector as they are fragile.
  4. LG G Pad 7.0 LTE Front Facing Camera Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • There is a light adhesive holding the camera in the device.
    • Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device.
  5. LG G Pad 7.0 LTE Front Facing Camera Replacement: 手順 5、 1の画像 1
    • Pry the audio jack from the device using a spudger.
  6. LG G Pad 7.0 LTE Front Facing Camera Replacement: 手順 6、 1の画像 1
    • Remove the 7 Black 3mm PH0 screws from the motherboard (red markers).
  7. LG G Pad 7.0 LTE Front Facing Camera Replacement: 手順 7、 1の画像 1
    • Remove the Motherboard.
  8. LG G Pad 7.0 LTE Front Facing Camera Replacement, Front Facing Camera: 手順 8、 1の画像 1
    • Gently pull up on the camera to remove it.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Fadi Bitar
メンバー登録日: 09/26/16
880 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 14-6, Eyestone Fall 2016 USF Tampa, Team 14-6, Eyestone Fall 2016人のメンバー
USFT-EYESTONE-F16S14G6
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 6
今までの合計 206
