メインコンテンツにスキップ
LG G Pad 10.1 Rear Facing Camera Replacement
必要な工具と部品
  1. LG G Pad 10.1 Rear Facing Camera Replacement, Rear Case: 手順 1、 1の画像 1
    • To remove the back panel of the device, start by attempting to fit the plastic opening tool in the crease between the screen and the back panel of the tablet.
    • Try opening picks if the case is not flexing enough, or if it is already cracked to prevent further damage.
    • You can use your hands to push against the corners of the device to attempt to make the gap larger for your plastic opening tool to fit in.
    • If you are replacing your screen because it is damaged, it may be useful to pick away at some of the glass to expose the clips in the edges of the plastic.
    • Insert the corners of your plastic opening tool into the slots that are on the very outside edge of your device to start disconnecting the panel.
    • On some models, there is a vertical strip of adhesive between the battery and the back cover on the left side of the Verizon logo. Be careful not to damage the battery when separating the adhesive!
  2. LG G Pad 10.1 Rear Facing Camera Replacement: 手順 2、 1の画像 1
    • Once the edge of your device's panel is separate from the screen, continue moving around the outside of the device while continuing to pry the two pieces apart from each other.
  3. LG G Pad 10.1 Rear Facing Camera Replacement: 手順 3、 1の画像 1
    • Insert another plastic opening tool (or a similar tool) between the screen and the back panel on the opposite side of the device to hold it open.
  4. LG G Pad 10.1 Rear Facing Camera Replacement: 手順 4、 1の画像 1
    • Disconnect the battery by inserting the point of a spudger underneath the white tabs on either side of the connector and gently pry up.
  5. LG G Pad 10.1 Rear Facing Camera Replacement, Rear Facing Camera: 手順 5、 1の画像 1
    • Locate the back camera at the far end of the motherboard, towards the lower center of the device.
    • Separate the connection to the motherboard with the spudger by gently prying them apart.
  6. LG G Pad 10.1 Rear Facing Camera Replacement: 手順 6、 2の画像 1 LG G Pad 10.1 Rear Facing Camera Replacement: 手順 6、 2の画像 2
    • Pull the camera upwards to remove it from the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Alex Roszkowski
メンバー登録日: 09/03/15
2,333 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team 15-1, Blackwell Fall 2015 USF Tampa, Team 15-1, Blackwell Fall 2015人のメンバー
USFT-BLACKWELL-F15S15G1
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 10
今までの合計 491
