メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Fortune Screen Replacement
必要な工具と部品
  1. LG Fortune Screen Replacement, Battery: 手順 1、 2の画像 1 LG Fortune Screen Replacement, Battery: 手順 1、 2の画像 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
    FixBotに聞いてみる
  2. LG Fortune Screen Replacement: 手順 2、 2の画像 1 LG Fortune Screen Replacement: 手順 2、 2の画像 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
    FixBotに聞いてみる
  3. LG Fortune Screen Replacement, Motherboard: 手順 3、 3の画像 1 LG Fortune Screen Replacement, Motherboard: 手順 3、 3の画像 2 LG Fortune Screen Replacement, Motherboard: 手順 3、 3の画像 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
    FixBotに聞いてみる
  4. LG Fortune Screen Replacement: 手順 4、 1の画像 1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
    FixBotに聞いてみる
  5. LG Fortune Screen Replacement: 手順 5、 1の画像 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
    FixBotに聞いてみる
  6. LG Fortune Screen Replacement: 手順 6、 1の画像 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
    FixBotに聞いてみる
  7. LG Fortune Screen Replacement: 手順 7、 1の画像 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
    FixBotに聞いてみる
  8. LG Fortune Screen Replacement, Rear Camera: 手順 8、 2の画像 1 LG Fortune Screen Replacement, Rear Camera: 手順 8、 2の画像 2
    • Unplug the camera from the phone using a metal spudger to get underneath the tape and remove the camera.
    • This will require a bit of force. Don't be afraid to apply the necessary amount to remove.
    FixBotに聞いてみる
  9. LG Fortune Screen Replacement, Screen: 手順 9、 2の画像 1 LG Fortune Screen Replacement, Screen: 手順 9、 2の画像 2
    • You will remove the microphone from underside of the screen.
    • The microphone will be located on the bottom right side of the device
    • Once the mic is off, the screen is by itself and ready to be replaced.
    FixBotに聞いてみる
終わりに
7 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Cori Johnson
メンバー登録日: 04/08/19
537 ポイント
5のガイドは作成済み
チーム
1件のガイドコメント
Haden Miller - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 47
今までの合計 4,781
