メインコンテンツにスキップ
LG Fortune Motherboard Replacement
必要な工具と部品
  1. LG Fortune Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG Fortune Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
  2. LG Fortune Motherboard Replacement: 手順 2、 2の画像 1 LG Fortune Motherboard Replacement: 手順 2、 2の画像 2
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
  3. LG Fortune Motherboard Replacement, Motherboard: 手順 3、 3の画像 1 LG Fortune Motherboard Replacement, Motherboard: 手順 3、 3の画像 2 LG Fortune Motherboard Replacement, Motherboard: 手順 3、 3の画像 3
    • Using a PH000 screwdriver, remove the ten 4mm screws on the back panelling.
    • Remove the back panelling from the device with your fingers or a spudger.
    • Work slowly side to side to release this back casing and expose the motherboard.
  4. LG Fortune Motherboard Replacement: 手順 4、 1の画像 1
    • Unplug the video card from the motherboard with a spudger or plastic opening tool.
    • Using the metal spudger as shown in the photos has the potential to damage your device.
  5. LG Fortune Motherboard Replacement: 手順 5、 1の画像 1
    • Unplug the front facing camera press fit connector from the motherboard by prying upwards with a spudger or plastic opening tool.
    • Using a metal spudger as shown in the photos could potentially damage your device.
  6. LG Fortune Motherboard Replacement: 手順 6、 1の画像 1
    • Unplug the rear facing camera ribbon cable from the motherboard by prying up the press fit connector with a spudger.
    • Using a metal spudger as shown in the photos has the potential to damage your device. Choose an ESD safe tool instead.
  7. LG Fortune Motherboard Replacement: 手順 7、 1の画像 1
    • Use the spudger to pry off the motherboard from the rest of the device on the top left corner down to the bottom right corner
終わりに
作成者
3人の作成者と共同で作成されました。
Cori Johnson
メンバー登録日: 04/08/19
531 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 595
