はじめに
This is how to replace the battery in the 2011 LG Extravert.
必要な工具と部品
Remove the case on the back of the cell phone by pulling up on the little indent with your fingernail or a Spudger in the bottom of the phone.
After you pull off the case, the battery is right under it. All you have to do is put you Spudger or fingernail into the indent on the right side of the battery and pull up.
ある他の人がこのガイドを完成しました。
