メインコンテンツにスキップ
LG Escape (p870) Rear Camera Replacement
必要な工具と部品
  1. LG Escape (p870) Rear Camera Replacement, Battery: 手順 1、 2の画像 1 LG Escape (p870) Rear Camera Replacement, Battery: 手順 1、 2の画像 2
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Rear Camera Replacement: 手順 2、 2の画像 1 LG Escape (p870) Rear Camera Replacement: 手順 2、 2の画像 2
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Rear Camera Replacement, Loudspeaker Assembly: 手順 3、 1の画像 1
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Rear Camera Replacement: 手順 4、 2の画像 1 LG Escape (p870) Rear Camera Replacement: 手順 4、 2の画像 2
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
  5. LG Escape (p870) Rear Camera Replacement, Rear Camera: 手順 5、 1の画像 1
    • Remove the remaining 6 screws securing the plastic frame to the back housing
  6. LG Escape (p870) Rear Camera Replacement: 手順 6、 3の画像 1 LG Escape (p870) Rear Camera Replacement: 手順 6、 3の画像 2 LG Escape (p870) Rear Camera Replacement: 手順 6、 3の画像 3
    • Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
    • Continue working your way around the phone, prying carefully with your prying tool
    • When you work the frame free, set it aside
  7. LG Escape (p870) Rear Camera Replacement: 手順 7、 1の画像 1
    • Use a plastic spudger or safe-open pry tool to release the camera's flex cable from its connector
    • Remove the camera from the housing and set it aside
終わりに
作成者
2人の作成者と共同で作成されました。
Brad
メンバー登録日: 08/12/12
1,908 ポイント
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 455
