はじめに
A working charging port is a mandatory part of making sure your device works. If you are having issues with your LG Enact charging port not working properly, this guide will help you replace it.
Be sure the device is fully powered off and be sure to follow the steps correctly.
必要な工具と部品
Unplug the four ports connected to the motherboard.
Disconnect the two wires on top of the battery.
Disconnect the two wires under the battery.
Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
もう少しです!
終わりに
