メインコンテンツにスキップ
LG EnV VX9900 Number Keypad Replacement
必要な工具と部品
  1. LG EnV VX9900 Number Keypad Replacement, Battery: 手順 1、 1の画像 1
    • Place the phone so the screen side is facing down.
    • Locate the latch at the end of the phone, opposite of the camera.
  2. LG EnV VX9900 Number Keypad Replacement: 手順 2、 1の画像 1
    • Push/pull the latch away from the camera, causing the battery to pop out.
  3. LG EnV VX9900 Number Keypad Replacement: 手順 3、 1の画像 1
    • Remove the battery.
  4. LG EnV VX9900 Number Keypad Replacement, Circuit Board and Full Key Board: 手順 4、 2の画像 1 LG EnV VX9900 Number Keypad Replacement, Circuit Board and Full Key Board: 手順 4、 2の画像 2
    • Remove the 5 screw covers on the back of the phone using a Push Pin.
  5. LG EnV VX9900 Number Keypad Replacement: 手順 5、 1の画像 1
    • With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
    • Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
  6. LG EnV VX9900 Number Keypad Replacement: 手順 6、 2の画像 1 LG EnV VX9900 Number Keypad Replacement: 手順 6、 2の画像 2
    • Open the phone.
  7. LG EnV VX9900 Number Keypad Replacement: 手順 7、 2の画像 1 LG EnV VX9900 Number Keypad Replacement: 手順 7、 2の画像 2
    • Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
    • Prying open the part just to the left of the right hinge can be difficult.
    • Remove the back colored casing and set it to the side.
  8. LG EnV VX9900 Number Keypad Replacement: 手順 8、 2の画像 1 LG EnV VX9900 Number Keypad Replacement: 手順 8、 2の画像 2
    • Gently pry and detach the connection located near the hinge with fingers.
  9. LG EnV VX9900 Number Keypad Replacement: 手順 9、 2の画像 1 LG EnV VX9900 Number Keypad Replacement: 手順 9、 2の画像 2
    • The circuit board and the key board will be attached, as shown in the second picture.
    • Lift them both out from the rest of the phone.
    • Do not try to the detach key board pad from the circuit board. They are replaced as a unit.
  10. LG EnV VX9900 Number Keypad Replacement, LCD Screen: 手順 10、 1の画像 1
    • After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
  11. LG EnV VX9900 Number Keypad Replacement: 手順 11、 1の画像 1
    • Careful! The paint is easy to scratch.
    • Remove the 4 screw covers from top piece of phone by using a Push Pin.
  12. LG EnV VX9900 Number Keypad Replacement: 手順 12、 1の画像 1
    • Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
  13. LG EnV VX9900 Number Keypad Replacement: 手順 13、 3の画像 1 LG EnV VX9900 Number Keypad Replacement: 手順 13、 3の画像 2 LG EnV VX9900 Number Keypad Replacement: 手順 13、 3の画像 3
    • Be careful while breaking the adhesive connecting the speaker and the casing in the following sub step so that you do not tear any wires.
    • Pry open the colored casing using the Plastic Pry Tool.
    • Remove the number pad and place it to the side.
  14. LG EnV VX9900 Number Keypad Replacement: 手順 14、 2の画像 1 LG EnV VX9900 Number Keypad Replacement: 手順 14、 2の画像 2
    • Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
  15. LG EnV VX9900 Number Keypad Replacement: 手順 15、 1の画像 1
    • The pieces connected by wires are magnets and are removable.
    • Remove the LCD Screen.
  16. LG EnV VX9900 Number Keypad Replacement, Number Keypad: 手順 16、 1の画像 1
    • The Number Keypad and its metal casing are attached to the clear plastic screen that the LCD Screen was in. Replace both the Keypad and the casing as a unit.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Nathan Farnum
メンバー登録日: 04/05/12
72 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 15-15, Forte Spring 2012 Cal Poly, Team 15-15, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S15G15
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,041
