メインコンテンツにスキップ
LG EnV Touch VX11000 Screen Assembly Replacement
必要な工具と部品
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: 手順 1、 1の画像 1
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 2、 1の画像 1
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 3、 2の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 3、 2の画像 2
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: 手順 4、 2の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: 手順 4、 2の画像 2
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 5、 1の画像 1
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 6、 2の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 手順 7、 3の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 手順 7、 3の画像 2 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: 手順 7、 3の画像 3
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 8、 2の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 8、 2の画像 2
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 9、 2の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 9、 2の画像 2
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 10、 1の画像 1
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 11、 3の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 11、 3の画像 2 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 11、 3の画像 3
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: 手順 12、 2の画像 1 LG EnV Touch VX11000 Screen Assembly Replacement: 手順 12、 2の画像 2
    • Unplug the connector from the screen.
終わりに
3 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Rachel Smith
メンバー登録日: 09/30/13
593 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G2
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,123
