はじめに
If the keyboard on your LG EnV Touch VX11000 is unresponsive or malfunctioning, you may need to replace it. This guide will show you how to replace the keyboard on an LG EnV Touch VX11000.
パーツ
パーツは必要ありません。
  1. Turn the phone off.
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. Slide the release latch down and toward you while lifting up on the left side of the battery cover.
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. Lift the edge of the battery to remove it. Lift the edge of the battery to remove it.
    • Lift the edge of the battery to remove it.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
  5. Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers. Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  6. Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  7. Use a plastic opening tool or your fingernail to pry off the back case. The camera and volume keys will fall off.
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  8. Use your hands to open the phone, separating the keyboard frame from the screen.
    • Use your hands to open the phone, separating the keyboard frame from the screen.
    • Using your thumbs, gently separate the motherboard from the frame, and the keyboard will fall out.
まとめ
ある他の人がこのガイドを完成しました。
Rachel Smith
メンバー登録日: 2013年09月30日
578 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 13-2, Forte Fall 2013 Cal Poly, Team 13-2, Forte Fall 2013人のメンバー
CPSU-FORTE-F13S13G2
4 メンバー
10のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 306
