メインコンテンツにスキップ
LG Dare Logic Board Replacement
必要な工具と部品
  1. LG Dare Logic Board Replacement, Battery: 手順 1、 2の画像 1 LG Dare Logic Board Replacement, Battery: 手順 1、 2の画像 2
    • Remove the back cover by firmly pressing against the raised lip on the back panel. Slide the cover towards the top of the phone.
  2. LG Dare Logic Board Replacement: 手順 2、 3の画像 1 LG Dare Logic Board Replacement: 手順 2、 3の画像 2 LG Dare Logic Board Replacement: 手順 2、 3の画像 3
    • Remove the battery by placing your fingernail or a opening tool in the recessed edge and lift the battery out.
  3. LG Dare Logic Board Replacement, Logic Board: 手順 3、 2の画像 1 LG Dare Logic Board Replacement, Logic Board: 手順 3、 2の画像 2
    • Use the #00 screwdriver to remove the six 4mm phillips screws located around the edges of the phone.
  4. LG Dare Logic Board Replacement: 手順 4、 3の画像 1 LG Dare Logic Board Replacement: 手順 4、 3の画像 2 LG Dare Logic Board Replacement: 手順 4、 3の画像 3
    • Lift the back plastic cover off by moving the opening tool around the edges of the phone.
    • Wedging the opening tool in several places on the bottom of the phone will help release small tabs that hold the back to the front frame.
    • The side buttons may fall out when removing the back plastic.
  5. LG Dare Logic Board Replacement: 手順 5、 3の画像 1 LG Dare Logic Board Replacement: 手順 5、 3の画像 2 LG Dare Logic Board Replacement: 手順 5、 3の画像 3
    • Pull off the back plastic panel.
    • Remove the buttons from the edge of the frame. The buttons are [lock], [volume control], [speaker], and [camera].
  6. LG Dare Logic Board Replacement: 手順 6、 1の画像 1
    • Disconnect the three ribbon connectors from the motherboard.
  7. LG Dare Logic Board Replacement: 手順 7、 3の画像 1 LG Dare Logic Board Replacement: 手順 7、 3の画像 2 LG Dare Logic Board Replacement: 手順 7、 3の画像 3
    • Remove the LED.
    • Remove the camera connector.
    • Remove the camera sensor from the logic board. Squeeze the sides of the camera sensor firmly and pull straight up.
  8. LG Dare Logic Board Replacement: 手順 8、 1の画像 1
    • Open the USB port cover.
  9. LG Dare Logic Board Replacement: 手順 9、 3の画像 1 LG Dare Logic Board Replacement: 手順 9、 3の画像 2 LG Dare Logic Board Replacement: 手順 9、 3の画像 3
    • Use the opening tool to lift up the green logic board in all areas and remove it.
    • The logic board may require some force to remove because it is taped to the plastic frame.
    • When removing the logic board, be careful not to tear any of the ribbon cables or side buttons.
終わりに
To re-assemble your device, follow these instructions in reverse order.
2 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Haoyan Huang
メンバー登録日: 01/26/12
151 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 9-4, Regan Winter 2012 Cal Poly, Team 9-4, Regan Winter 2012人のメンバー
CPSU-REGAN-W12S9G4
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 2,310
