1. Insert the plastic opener into the slot at the top of the device. Apply gentle pressure with the plastic tool to pop the back case off. Apply gentle pressure with the plastic tool to pop the back case off.
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery. Use the plastic opener to lift, and remove, the device battery.
    • Use the plastic opener to lift, and remove, the device battery.
  3. Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
    当社のショップを閲覧する
  4. Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  5. Use the plastic opener to pry the rear case loose. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place. This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  6. Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker. Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
    • Use the TOOL to pry open the plastic piece located at the bottom of the rear case. This piece contains the speaker.
まとめ
Nick White
メンバー登録日: 2013年10月18日
827 ポイント
8のガイドは作成済み
チーム
Clemson, Team 13-1, Benson Fall 2013 Clemson, Team 13-1, Benson Fall 2013人のメンバー
CLEM-BENSON-F13S13G1
3 メンバー
16のガイドは作成済み
コメントを追加する
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 4
今までの合計 228
