はじめに
Most of the LG Cosmos 2 must be disassembled prior to replacing the buttons. Follow these steps to complete this task.
必要な工具と部品
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
There’s a tricky part not visible in this photo. The ribbon cable may be attached with a little bit of double sticky tape. Pry it up carefully with a spudger or other plastic tool.
Jen Morris - 返信
Use the spudger to pry the metal piece loose.
Remove the metal piece along with the two ribbon cables.
Seems to be missing a step here: how to remove the third ribbon cable (short one on lower right corner of photo)? Mine is under black plastic cover and blue plastic film. I had to move to Step 19 to take the black plastic piece off.
Jen Morris - 返信
