はじめに
Most of the LG Cosmos 2 must be disassembled prior to replacing the buttons. Follow these steps to complete this task.
必要な工具と部品
Insert the plastic opener into the slot at the top of the device.
Apply gentle pressure with the plastic tool to pop the back case off.
Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
