はじめに
This guide explains how to remove the front buttons of the LG Chocolate Touch VX-8575. Be prepared to handle and keep track of very small pieces, including 3.5mm screws.
必要な工具と部品
Using your thumb, apply pressure to the back cover while sliding it down and off.
Lift and remove the back cover.
Locate the battery. It is the large black rectangle with the LG logo, a model number, and battery information.
Using your thumb or thumbnail, insert a thumb into the crescent indent just below the battery and apply pressure to the battery, pushing up and away from the phone. It will come out easily.
Leave the phone screen down on a table and locate the six 3.5mm Phillips screws around the edges of the back of the phone. There are four in each corner and two half way up on the sides.
Use a Phillips #00 screwdriver to unscrew all six 3.5mm Phillips screws.
With the phone still facing upwards, identify and remove the three buttons at the bottom end that say "Send", "Clear", and "End." They should come off easily.
