メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide shows how to replace the battery in the LG Chocolate Touch VX-8575. No background information is necessary.
  1. Using your thumb, apply pressure to the back cover while sliding it down and off. Lift and remove the back cover.
    • Using your thumb, apply pressure to the back cover while sliding it down and off.
    • Lift and remove the back cover.
  2. Locate the battery. It is the large black rectangle with the LG logo, a model number, and battery information. Using your thumb or thumbnail, insert a thumb into the crescent indent just below the battery and apply pressure to the battery, pushing up and away from the phone.  It will come out easily. Using your thumb or thumbnail, insert a thumb into the crescent indent just below the battery and apply pressure to the battery, pushing up and away from the phone.  It will come out easily.
    • Locate the battery. It is the large black rectangle with the LG logo, a model number, and battery information.
    • Using your thumb or thumbnail, insert a thumb into the crescent indent just below the battery and apply pressure to the battery, pushing up and away from the phone. It will come out easily.
終わりに
ある他の人がこのガイドを完成しました。
Jake Puppo
メンバー登録日: 2012年04月03日
23 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 5-1, Forte Spring 2012 Cal Poly, Team 5-1, Forte Spring 2012人のメンバー
CPSU-FORTE-S12S5G1
5 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,382
