メインコンテンツにスキップ
LG Chocolate Sliding Mechanism Replacement
必要な工具と部品
  1. LG Chocolate Sliding Mechanism Replacement, Battery: 手順 1、 2の画像 1 LG Chocolate Sliding Mechanism Replacement, Battery: 手順 1、 2の画像 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Sliding Mechanism Replacement, Back Cover: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Sliding Mechanism Replacement: 手順 3、 3の画像 1 LG Chocolate Sliding Mechanism Replacement: 手順 3、 3の画像 2 LG Chocolate Sliding Mechanism Replacement: 手順 3、 3の画像 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Sliding Mechanism Replacement, Sliding Front: 手順 4、 1の画像 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Sliding Mechanism Replacement: 手順 5、 2の画像 1 LG Chocolate Sliding Mechanism Replacement: 手順 5、 2の画像 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Sliding Mechanism Replacement: 手順 6、 2の画像 1 LG Chocolate Sliding Mechanism Replacement: 手順 6、 2の画像 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Sliding Mechanism Replacement: 手順 7、 1の画像 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Sliding Mechanism Replacement, Sliding Mechanism: 手順 8、 1の画像 1
    • Use a Phillips #00 to remove the 4 screws that hold the sliding mechanism in place.
  9. LG Chocolate Sliding Mechanism Replacement: 手順 9、 1の画像 1
    • Remove sliding mechanism.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Thomas
メンバー登録日: 01/18/13
91 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G46
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 356
