メインコンテンツにスキップ
LG Chocolate Side Buttons Replacement
必要な工具と部品
  1. LG Chocolate Side Buttons Replacement, Battery: 手順 1、 2の画像 1 LG Chocolate Side Buttons Replacement, Battery: 手順 1、 2の画像 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Side Buttons Replacement, Back Cover: 手順 2、 1の画像 1
    • Use a Phillips #00 screwdriver to unscrew the four Phillips #00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. LG Chocolate Side Buttons Replacement: 手順 3、 3の画像 1 LG Chocolate Side Buttons Replacement: 手順 3、 3の画像 2 LG Chocolate Side Buttons Replacement: 手順 3、 3の画像 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. LG Chocolate Side Buttons Replacement, Sliding Front: 手順 4、 1の画像 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Side Buttons Replacement: 手順 5、 2の画像 1 LG Chocolate Side Buttons Replacement: 手順 5、 2の画像 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Side Buttons Replacement: 手順 6、 2の画像 1 LG Chocolate Side Buttons Replacement: 手順 6、 2の画像 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Side Buttons Replacement: 手順 7、 1の画像 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Side Buttons Replacement, LCD Board: 手順 8、 3の画像 1 LG Chocolate Side Buttons Replacement, LCD Board: 手順 8、 3の画像 2 LG Chocolate Side Buttons Replacement, LCD Board: 手順 8、 3の画像 3
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. LG Chocolate Side Buttons Replacement: 手順 9、 2の画像 1 LG Chocolate Side Buttons Replacement: 手順 9、 2の画像 2
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. LG Chocolate Side Buttons Replacement: 手順 10、 1の画像 1
    • Unhook the ribbon cable using that flat side of a spudger.
  11. LG Chocolate Side Buttons Replacement: 手順 11、 1の画像 1
    • Next, carefully remove the tape from the LCD board.
  12. LG Chocolate Side Buttons Replacement: 手順 12、 2の画像 1 LG Chocolate Side Buttons Replacement: 手順 12、 2の画像 2
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. LG Chocolate Side Buttons Replacement, Side Buttons: 手順 13、 1の画像 1
    • The side buttons can now be accessed freely.
終わりに
作成者
5人の作成者と共同で作成されました。
Charles Yoon
メンバー登録日: 01/18/13
64 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G46
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 190
