メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
パーツ
パーツは指定されていません。
  1. Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly. The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
    • Unscrew the four Phillips 00 screws on the four corners under the battery to unfasten the back case from the phone.
  3. Pry the case off using a plastic opening tool. Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo. The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
    • Pry the case off using a plastic opening tool.
    • Continue working the plastic opening tool around the sides of the device, unhooking the eight tabs securing the back cover to the rest of the phone as shown in the second photo.
    • The back speaker will be connected to the motherboard, and must be disconnected to remove the case.
  4. Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it. Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. Pry off the plastic tabs that cover two screws, as shown in the first picture. Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. Pry off the back cover from the front of the case using a plastic opening tool.
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. Pry the front speaker and wireless receiver out of the front case using a spudger. They may be taped into the case, so don't be afraid to pry hard. They may be taped into the case, so don't be afraid to pry hard.
    • Pry the front speaker and wireless receiver out of the front case using a spudger.
    • They may be taped into the case, so don't be afraid to pry hard.
  9. Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case. Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
    • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
  10. Unhook the ribbon cable using that flat side of a spudger.
    • Unhook the ribbon cable using that flat side of a spudger.
  11. Next, carefully remove the tape from the LCD board.
    • Next, carefully remove the tape from the LCD board.
  12. Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger. The LCD Board in now accessible.
    • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
    • The LCD Board in now accessible.
  13. The LCD screen is no longer connected to the LCD board.
    • The LCD screen is no longer connected to the LCD board.
終わりに
2 の人々がこのガイドを完成させました。
Charles Yoon
メンバー登録日: 2013年01月18日
61 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 19-46, Regan Winter 2013 Cal Poly, Team 19-46, Regan Winter 2013人のメンバー
CPSU-REGAN-W13S19G46
4 メンバー
22のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 453
