はじめに
Use this guide to replace a damaged or malfunctioning LG Chocolate 3 Keypad.
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
もう少しです!
To reassemble this device, follow these instructions in reverse order.
終わりに
ある他の人がこのガイドを完成しました。
