はじめに
This guide will explain how to remove both the outside and inside LCD screens. This is a fairly difficult guide for the LG CU515 SKU 64743 Device. Removing the LCD screens will require many tools and steps. However, this guide will take you through each step in detail so as to make the process as easy as possible.
必要な工具と部品
手順1 Front Cover
注意: 手順 1-5 は、作業進行中としてマークされている ガイド から引用されています。
Separate the top half of the clamshell from the bottom half by first locating the two hinges.
Carefully pull to one side and immediately up. The top part should pop out of the hinge. Next slide the opposite direction to pull out of the other hinge.
