メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
This guide explains how to remove the front plastic screen covering from the phone. This is a fairly simple guide for the LG CU515 SKU 64743 Device. Removing the front screen covering will require only a plastic pry tool. This guide will take you through each step in detail so as to make the process as easy as possible.
ツール
パーツ
パーツは指定されていません。
  1. Carefully pry around the crevice of the entire plastic screen covering using a pry bar or some other type of sharp tool. Be careful when prying as the plastic covering can easily be bent or cracked. Once you have pried all the way around, using tweezers to pull the plastic screen completely off.
    • Carefully pry around the crevice of the entire plastic screen covering using a pry bar or some other type of sharp tool.
    • Be careful when prying as the plastic covering can easily be bent or cracked.
    • Once you have pried all the way around, using tweezers to pull the plastic screen completely off.
終わりに
2 の人々がこのガイドを完成させました。
Maggie
メンバー登録日: 2013年10月18日
680 ポイント
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 327
