はじめに
This guide will provide steps to remove the front cover of the cell phone in order to replace it. This is a fairly difficult guide for the LG CU515 SKU 64743 Device. Removing the front cover will require many tools and steps. However, this guide will take you through each step in detail so as to make the process as easy as possible.
必要な工具と部品
Separate the top half of the clamshell from the bottom half by first locating the two hinges.
Carefully pull to one side and immediately up. The top part should pop out of the hinge. Next slide the opposite direction to pull out of the other hinge.
ある他の人がこのガイドを完成しました。
