メインコンテンツにスキップ
LG CU515 Motherboard Replacement
必要な工具と部品
  1. LG CU515 Motherboard Replacement, Battery: 手順 1、 2の画像 1 LG CU515 Motherboard Replacement, Battery: 手順 1、 2の画像 2
    • Use your thumb to press down and slide off the back cover of the phone.
  2. LG CU515 Motherboard Replacement: 手順 2、 3の画像 1 LG CU515 Motherboard Replacement: 手順 2、 3の画像 2 LG CU515 Motherboard Replacement: 手順 2、 3の画像 3
    • Take out the battery by levering it out towards the bottom of the phone.
  3. LG CU515 Motherboard Replacement, Motherboard: 手順 3、 1の画像 1
    • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
  4. LG CU515 Motherboard Replacement: 手順 4、 1の画像 1
    • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
  5. LG CU515 Motherboard Replacement: 手順 5、 3の画像 1 LG CU515 Motherboard Replacement: 手順 5、 3の画像 2 LG CU515 Motherboard Replacement: 手順 5、 3の画像 3
    • Push the spudger into the crack separating the two pieces of the phone.
    • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
    • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
    • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
  6. LG CU515 Motherboard Replacement: 手順 6、 1の画像 1
    • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
  7. LG CU515 Motherboard Replacement: 手順 7、 1の画像 1
    • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
  8. LG CU515 Motherboard Replacement: 手順 8、 1の画像 1
    • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
    • Replace the motherboard with a new one.
終わりに
作成者
6人の作成者と共同で作成されました。
Zack Mintzer
メンバー登録日: 04/16/13
1 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 21-55, Johann Spring 2013 Cal Poly, Team 21-55, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S21G55
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 358
