この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you disassemble the top half of the phone. By completing this you will have access to the display connections and hinge.
必要な工具と部品
Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
You should notice that the number pad is loose and can simply be taken out of the open phone casing.
Remove the four rubber covers from the front screen using a metal spudger.
もう少しです!
終わりに
