To remove the battery, grasp the top front edge of the battery and pull the battery away from the phone.
When installing the new battery, have the metal contacts of the phone match up with the metal contacts of the battery.
Insert the metal spudger between the keypad assembly and back cover assembly and pry the two assemblies apart.
Pry gently as to not break the plastic clips that hold the two assemblies together.
Work your way around the perimeter of the phone with the metal spudger to separate the two assemblies.
Using the spudger, start to gently pry the motherboard from the back of the phone and work your way around the perimeter of the motherboard.
There are copper ribbon cables connected to each side of the motherboard leading to the buttons for volume control and the camera that need slid out of the phone casing as the motherboard is being removed.
There are three in total, but do not remove the top one from the phone casing yet.
Once the motherboard is not locked in place it will still be attached to the back phone casing by two wires, red and black, twisted together.
Use tweezers to grab the black piece that these wires are attached to and simply pull it off the motherboard.
You may need to flip the phone over so that the screen is facing down. Feel free to move the keypad assembly to the closed position for this step.
Remove the display ribbon cable from the back of the motherboard using tweezers.
Make sure to lift it so that you are pulling the entire thing off at once and not pulling off the flat piece at an angle.
Grasp either side of the motherboard and gently lift it away from the phone casing.
The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
1つの手順
全ガイド
小サイズ - 600px
中サイズ - 800px
大サイズ - 1200px
プレビュー
